- PROTECT YOUR RIDES WITH INNOVV -
INNOVV Dashcam Comparison
ItemINNOVV K3INNOVV K5INNOVV K6INNOVV K7INNOVV N1
Lens120° 6G WaterproofFront: 120° 7G Waterproof
Rear: 120° 6G Waterproof
Front: 120° 6G Waterproof
Front: 120° 6G+1IR Waterproof
Rear: 120° 6G+1IR Waterproof
Front: 120° 4G+1IR Waterproof
Rear: 120° 4G+1IR Waterproof
Lens DimensionsFront:Dia 2553.5mm Rear: Dia 2553.5mmFront:724825mm (DVR Intergrated)
Rear:Dia 25*53.5mm
Front: Dia 3276 mm Rear: Dia 2545mmFront: Dia 2545mm Rear: Dia 2545mmFront: Dia 2535mm Rear: Dia 2535mm
CMOS AdvantagesFront : Sony STARVIS 291
Rear : Sony STARVIS 291
High Sensitivity
Day and night balance
Front: Sony STARVIS 415
4K, HDR, Outstanding Low-light Performance
Rear: Sony STARVIS 291
WDR, Improved Visible Light and Near Infrared Sensitivity
Front : Sony STARVIS 335
2K Day and night balance
Rear:Sony STARVIS 307
Rear: Sony STARVIS 335
SONY STARVIS IMX307
Lens CaseAluminiumAluminiumAluminiumAluminiumAluminium
DVR DimensionsPlastic Cover + Aluminum Base 80.556.315mmAll Aluminum
724825mm
Aluminum + Plastic back shell
Dia 32*76 mm
Plastic Cover + Aluminum Base 815625mmPlastic Cover + Aluminum Base 1508522mm
Video Resolutions1080p 30fps + 1080p 30fps4K 30fps + 1080p 30fps2K 30fps + 1080p 30fps2K@30FPS+2K@30FPS1080P+1080P 30FPS
720p 60fps + 720p 60fps4K 30fps + 720p 30fps1080P 30fps + 1080p 30fps1080P@30FPS+1080P@30FPS+EIS1080P+1080P 30FPS
2.7K 60fps + 1080p 30fps1080P@60FPS+1080P@60FPS
2.7K 60fps + 720p 30fps
1080p 96fps + 1080p 30fps
1080p 96fps + 720p 60fps
WiFi2.4 GHz2.4GHz / 5.8 GHz2.4 GHz2.4GHz / 5.8 GHz2.4GHz/5.80GHz
MicrophoneExternal Mic
(2.0 meter/ 6.56 Feet)
External Mic
Internal MicExternal Mic
Internal Mic
G SensorYes - Automatic Incident DetectionYes - Automatic Incident DetectionYes - Automatic Incident DetectionYes - Automatic Incident DetectionYes - Automatic Incident Detection
Parking ModeYesYes/YesYes
Video FormatTS or MP4TS or MP4MP4MP4MP4
IP 67YesYesYesYesYes
Mobile AppYes iOS 8.3 and above and Android 5.1 and aboveYes iOS 8.3 and above and Android 5.1 and aboveYes iOS 8.3 and above and Android 5.1 and aboveYes iOS 8.3 and above and Android 5.1 and aboveiOS Car Play,Android Auto
Data InterfaceMicro USBMicro USBUSB Type C//
GPS1HZ5HZ/10HZ/
Power SupplyDC ConveterDC ConveterDC Conveter / USB - MC Verssion
USB - BC Verssion
Micro SD Card (Max)256GB512GB256GB512GB256GB
512GB (Default settings)/20 Hours/38.38 Hours/
256GB (Default settings)13.4 Hours10 Hours20 Hours19.19 Hours
128GB (Default settings)6.7 Hours5 Hours10 Hours9.59 Hours
64GB (Default settings)3.3 Hours2.5 Hours5 Hours4.80 Hours
32GB (Default settings)1.6 Hours1.25 Hours2.5 Hours2.40 Hours
Shopping Cart
