Is the N2 for BMW /N3 compatible with my BMW?
The N2 for BMW and N3 are designed for BMW motorcycles equipped with BMW Nav Prep 5/6 or the BMW ConnectedRide keyless mount, supporting quick-release installation.
Wonder Wheel support varies by model. Please refer to the compatibility list below.
Not on the list? Contact our online chat or email us at cs@innovv.com / info@innovv.com.
Check compatibility with your BMW
Model Years Native data access Native Wonder Wheel To Access Wonder Wheel Control Navigation Software Update(272) 3-Pin Nav Interface
R1300 GS 2024 and later -
R1300 GSA 2024 and later -
R1250 GS 2023 and later -
R1250 GS ADV 2020-2023 -
R1250 GS 2019-2024 and later -
R1250 RS 2019-2023 -
R1200 GS ADV 2013-2018 -
R1200 GS 2013-2018 -
R1200 RS 2016-2018 -
F750 GS 2020 and later -
F750 GS Comfort 2020 and later -
F800GS 2024 and later -
F850 GS 2018 and later -
F850 GSA 2019 - 2023 -
F900 GS /GSA 2024 and later -
F900 XR 2020 and later - -
S 1000XR 2015 and later -
R1200 R 2013-2015 -
F800 GS 2014-2018 -
F800 GS ADV 2013-2018 -
S1000 R 2014-2025 -
Important Notes!!!
To use the Wonder Wheel for control, you must first verify that the SA 272 (“Preparation for Navigation Unit”) option is activated​ on your motorcycle.
  • If SA 272 is not activated, the Wonder Wheel will not function​ for device control, and device will may not be able to access native data​ (e.g., RPM, gear).
Supported Mounts Base
1. BMW Navigation Mount 5/6 (with Key Lock, No Front Buttons)
Also known as the BMW Navigator mount for Nav V/VI. This is the OEM “Navigation Prep” mount that powers and communicates with accessories via pogo-pin connectors.
2. New Keyless Electric BMW ConnectedRide Mount (Motorized Locking Mechanism)
The latest “electric/keyless” mount, designed for 2024–2026+ models (BMW part number: 65 90 5 B6C 8C0). It uses an electronic locking/unlocking mechanism instead of a mechanical key.
3. Compatibility Note: Beginning February 5, 2026, the N2 for BMW will offer Wonder Wheel support for the keyless bracket design.
❌Not Supported
Any BMW mount with physical buttons
Example: Older 4-button navigation mounts.
How to Identify Your Mount in 10 Seconds
Look for buttons:​
Buttons = older 4-button mount → Not supported.
Look for a key slot:​
A key lock on the side and a clean bezel without buttons usually indicates a Nav Prep 5/6​ → Supported.
Listen/feel for an electric latch:​
If it opens/closes electronically and has no key, it’s the new keyless electric mount (BMW part #65 90 5 B6C 8C0)​ → Supported.
Check for the center pogo-pin pad:​
Both supported mounts feature a BMW pogo-pin contact block​ in the center, which provides power and data transfer.
💡 BMW Version vs Universal Version
What makes the BMW Version different?
Compared with the universal version, the BMW Version offers deeper integration for selected BMW motorcycles:
✅ Wonder Wheel Control
Operate key functions directly with the OEM BMW Wonder Wheel for a more factory-style user experience
(Please refer to the compatibility list above)
✅ Motorcycle Data Display
View supported bike data directly on the screen, including speed, gear, fuel level, and TPMS information
✅ BMW TFT Integration
Works with the BMW TFT system for a more integrated riding setup
⚠️ More specific compatibility requirements
The BMW Version requires an original, unmodified BMW navigation mount and is only compatible with selected BMW models
📌 If you only need Apple CarPlay or Android Auto and do not need Wonder Wheel control, bike data display, or TFT integration, the Universal Version is the better choice.
It offers broader compatibility and can be used on any motorcycle with a suitable mounting solution and power supply. For BMW riders, if the device can be mounted properly and powered correctly, the Universal Version can be used.cements, or welcome customers to your store.
3-Pin Navigation Connector
If your BMW motorcycle has a 3-pin navigation connector but does not have the OEM navigation mount installed:
✅ You can purchase a BMW OEM navigation mount separately
✅ N3 also offers a dedicated BMW navigation mount
✅ Once the mount is installed, the BMW version can be properly mounted and used on your motorcycle
✅ The mount provides both the mounting point and power connection
💡 Tip: Please contact your BMW dealer to purchase the OEM navigation mount compatible with your motorcycle. If you are using N3, you can also choose the dedicated N3 BMW navigation mount directly.
TPMS (Tire Pressure Monitoring System)
If your BMW motorcycle is equipped with factory TPMS:
✅ The device can read and display your tire pressure data
✅ Data is sourced directly from your motorcycle’s existing TPMS system
✅ No additional accessories are required
If your BMW motorcycle does not have factory TPMS:
You can still add tire pressure monitoring by purchasing compatible TPMS accessories from our website (N3 only):
✅ Add TPMS functionality to your setup
✅ TPMS sensors designed specifically for motorcycles
✅ Easy to install on your tires
✅ Real-time tire pressure display on your INNOVV screen
💡 Tip: Browse our TPMS accessories or contact info@innovv.com to find the right TPMS solution for your BMW motorcycle.
No TFT Display? It may still work.
Even if your BMW motorcycle does not have a TFT display, the N2 BMW / N3 may still support Wonder Wheel control and selected bike data functions if:
✅ An OEM BMW navigation mount is installed
✅ The mount is unmodified
✅ The bike has factory Wonder Wheel control
✅ Data is available through the OEM mount contacts
Product comparison
Display
5.99" IPS Display
Display
6.5" IPS Display
Display
5.99" IPS Display
Waterproof
IP67 Waterproof
Waterproof
IP67 Waterproof
Waterproof
IP67 Waterproof
Compatibility
All Motorcycle Brands
Compatibility
BMW Cradle Compatible
Compatibility
Installation
Plug-and-Play
Installation
Plug-and-Play
Installation
Fixed Mount Design
Control
Standard Touch Control and Wonder Wheel Control
Control
Control
TPMS
External TPMS Supported
TPMS
Factory TPMS Only
TPMS
Camera
Optional Dual 1080P/2K Camera
Camera
not supported
Camera
Dual 2K Camera
Still Have Question?
If you cannot find your motorcycle in this compatibility list, or if you have any additional questions, please submit a support ticket or contact our support team directly at cs@innovv.com or info@innovv.com.
This site is protected by hCaptcha and the hCaptcha Privacy Policy and Terms of Service apply.
