Load video:
For First-Time Users
Installation Guide
You might want to know
Google Play Store
Download App
Apple Store
Download App
K3 Manual
Download
How To Update K3 Dashcam's Firmware
1. Click the above link to download the latest firmware named K3.bin to your computer.
2. Copy the K3.bin file to an SD card which shall be in FAT32 format. The file name must be the original name and other names could not work, such as K3(1).bin or K3(2).bin.
3. Insert the Micro SD card into your INNOVV DVR.
4. Power on your INNOVV camera system and the firmware will be automatically updated with the green light flashingerratically.
Once update is successful the blue light will be flashing on a regular basis appx once a second. If for any reason the update was not successful, please repeat the update.
K3 Firmware Version
V1.1.15 Update 20220521
Download
Changelog:
How could I download the user manual for my INNOVV K3?
You could kindly find the user manual for your INNOVV K3 from our Firmware & App and easily download one by clicking the icon.
1. Find the latest firmware for your INNOVV dash cam from ourFirmware & App
2. Copy the bin file to an SD card in FAT32 format
3. The file name must use the original name and there can be no other names
Recording Indicator on INNOVV K3's Remote Control flashes slowly and INNOVV K3 stops recording. What shall I do?
1. Please kindly check whether you are entering the Setting Interface or Camera Files Interface with INNOVV App on your phone when the INNOVV K3 dash cam system has been connected with your phone via Wi-Fi network. If yes, please kindly exit these two interfaces to further check the K3’s recording working status.
2. Please kindly change another TF card to check whether the INNOVV K3 could start recording or not.
Recording Indicator on INNOVV K3's Remote Control flashes qucikly and INNOVV K3 stops recording. What shall I do?
1. Please kindly check whether the TF card is inserted properly first.
2. Please kindly check whether the TF card is in FAT32 format.
3. If the TF card is inserted properly and it is in FAT32 format, please kindly change another normal TF card.
Please make sure that the distance between your phone and the INNOVV K3’s DVR is not that far away and there is no barriers between them.
What shall I do if I could not find the K3's Wi-Fi on my phone?
1. Please kindly check that whether you have disabled the Wi-Fi via Settings on INNOVV App.
2. Please kindly check that the blue Wi-Fi Indicator on INNOVV K3’s Remote Control is flashing slowly. If yes, the Wi-Fi is connecting, please kindly wait for seconds to make Wi-Fi connected.
