Based on 334 reviews
76%
(255)
16%
(55)
4%
(14)
0%
(1)
3%
(9)
5* equipment
I was pleasantly surprised by the ease of installation and the quality of the images from the INNOVV K7 Motorcycle Dashcam. I'm still exploring the system, but so far, I’m extremely satisfied. I just need to figure out how to download all the files at once.
my h5
got mine couple weeks ago very happy with it as also have k3 on my bike will buy again when i need to
Stephane Lecointre
envois rapide produit conforme je recommande
Buon prodotto con tutto il necessario per un montaggio fatto bene.
Mohammad Jamalzadeh
Good product, just I am wondering if someone stole the bike what’s the point for parking video
Just what I needed
Much larger footprint. Original pad came lose, this is much more stable.
Great Product
Very high quality and not particularly difficult to install. The biggest challenge was routing the cables to the mirrors without stress.
Overall, a highly recommended product.
Perfect
Great product easy to install and set up
Quality product, easy to install on the bike, plenty of instructions to aid fitment and function.
Works really well. Very happy with purchase. What price can you put on improving safety.
Steve Hewitt
Powerhub 3 ; Yes or No?
Just received my Powerhub 3 at the weekend. I was looking to install extra Innovv cameras on my pride and joy and after doing some research I settled on what I felt was the best value for money. I wasn’t disappointed. The quality of the Powerhub 3 and the ease of use was for me unbelievable. I do have arthritis in my hands and was worried that I might not be able to get it wired onto the bike. I had no reason to think that it might be hard as it was without doubt one of the easier extras that was given its space on the bike. It’s a switched live system so I’ve no issues with it running down my battery as it turns everything off after 10 seconds. Would I recommend? Without doubt. Would I use one again if I wanted to attach other electrical components to a bike? 100% yes and do I feel its value for money. A big YES.
Camera setup looks nice out of the box. Cant wait to install it.
Really looking forward to doing the install work myself. Just haven't had the time. Really looking forward to the continuous loop protection and the feature that starts the cams when it is bumped while parked. Packaged well and arrived quickly. Thanks SandIn MyCrack
Packaged very well instructions was good. Everything plugged in and worked seamlessly. The information that is provided by the GPS is so small on the picture you cannot read it. It needs to be much bigger.
K6 quality system
Well made and straightforward to fit. A great addition to any bike for more peace of mind
Excellenty dashcam system for motorcycle
Delivery was very quick. Instructions for setup were clear and process simple. Cables are well identified and easy to install. The App works well. Image quality is better than expected for a dashcam. I am extremely happy with my purchase and would definitely recommend it.
Very accurate Dashcam for Motorcycles
I installed the dashcam in my BMW R1250GSA and I didn’t have to do any modifications on the bike except the switched + (yellow wire). On the next day I catched alreafy some footings.
New dash cam
Easy to fit and footage really clear great bit of kit
Parking mode shortcomings
Everything about this product works as advertised…except for the parking mode. There is no g-force sensitivity adjustment while in parking mode and it takes quite a bit of force to set it off…which I feel is quite redundant for a parking monitor. If the g-force sensitivity was adjustable for the parking mode, I would give this product a 5/5. Hopefully the manufacturer reads this review and can eventually roll out a software update that addresses this issue.
Dear customer, you can adjust the level of G-sensor in the Settings. The specific operation has been sent to your email.
Motorcycle cam system
The install was simplistic and clear immaturity provided. As this system is generic it can result in a lot of excess calling require stowing.
К
RC6 With Dashcam & ThirdEYE
Красимир Русанов
Здравей
Все още не съм я монтирал и проверил как работи,за сега само за опаковката ви давам отличен
Dual K7 bundle for 2 bikes
I ordered the dual K7 -bundle for my and my wifes bikes. As I'm a professional, I installed them my self.
Package and product
Packaging is very professional and good looking. Everything what is needed is there. The product it self feels very high quality and with more careful inspection it proves to be just that. Perhaps the only thing that I would add is some extra bits for installation, such as the aluminium bent brackets, as it would give more options for those who don't have a workshop at their disposal. Now I had to fabricate a bracket to install the remote, but that was no problem.
Installation
The product it self is easy and pretty straight forward to install. The cable lengths for the cams are 1,5 and 2m and even on my Harley Street Glide the 2.0m cable was barely enough for the isntallation. I did order the extension cable but that was unnecessary after a bit more pondering and re-routing the cable. So, Im tending to think that if the cable length would be increased to 2.0m and 2,5m, no extension cables would be needed unless installing the system on a car or other motor vehicle.
The connectors have seals inside and the package even has a set of spare o-rings! Nice!
Video quality is either Good or Super Good, depending on the selected quality. 1080/30FPS+EIS is stable, but the Full2K is much better and does not really vibrate too much if you find a good location where to install the cameras to avoid the vibration.
Improvement suggestions
Increase the camera cable lengths to 2.0m and 2,5m, that will make sure that the cam system can be installed on larger bikes as well, without ordering extension cable(s).
As the central unit is most likely often istalled in such location where getting your hands on it might be a bit tricky, I would suggest that the memory card slot would be a separate unit with ~1m cable. That would make it a lot easier to get your hands on the memory card.
The phone app is good and works well, but is the WiFi really better than Bluetooth? I don't know, but connecting to the wifi is slow and sometimes downloading the videos fail, despite the fact that I've checked that the firmware is up to date.
My general, overall jugement is that for the money spent this is one of the best ones I've seen available and THAT is why I decided to buy the K7 for both of our bikes. I would have selected the N1 for my wifes Sportster but she declined the screen, so with K7 we went.
It would be interesting to test the K7 though, and see if that would be a good choice.
Packaging *****
Overall Quality ****
Instructions *****
Ease Of Installation *****
Phone App *****
Value for the money *****
Hello Jere, thank you for your detailed feedback and your love and support for our products. Thank you for your feedback on the improvement suggestions. This information is of great help to us or other motorcycle riders. We will do better. Wish you a pleasant and safe ride :)
I can't install my N1 until later this summer.
Works well, nice video!
Records beautiful clear video, easy to install. I accidentally ordered the motorbike version but actually wanted the cycle version. Shame that INNOV can't supply the cycle mounts separately (I asked). Otherwise, wifi slow to download.
A brilliant piece of kit
I bought the inflator to take on my motorbike journey to accompany my puncture repair kit. It inflates tyres quickly and precise. It has so many uses for anyone with bikes or cars. Its also very good quality and feels substantial
EVO Plus + Adapter 128GB
Patrick Van der Schatte Olivier
Werkt goed
De geheugenkaart werkt goed, makkelijk te plaatsen en snel te formatteren.
A nice edition
Having bought a helmet cam from Innovv before, when this came up to pre-order I thought why not. I has arrived and I've now used it on my bike and my wife's car tyres and I am nicely happy with it. It is not too large so I can fit it in my bags on my bike, inflates the tyres in a good speed and it looks like the battery life will be just what I need.
Obviously as I use it more and more I will get to know the positives and negatives but at the moment it is all positive.
