APP and Instruction Manual
Google Play Store
Download App
Apple Store
Download App
N2 - Manual
Download
N2 - Firmware
Download the latest firmware for the N2 here
Download
N2 Firmware
You can download the latest firmware for the N2 here.
Firmware Version Download
Latest Updates:
N2 Firmware V1.7 (0618):
CarPlay Stability:​ Resolved an issue causing the system to freeze when repeatedly entering CarPlay.
CarPlay Display:​ Default CarPlay layout is now set to Large Icons​ for improved visibility.
OTA Upgrade:​ Added a download progress bar​ during OTA updates for clearer status tracking.
Language Support:​ Added Italian​ to the list of supported languages.
Host Device Upgrade Instructions:
Starting with V1.7 (Jun 18 build), firmware updates can be performed by simply downloading the file to a microSD card.
  1. Take out the Micro SD card and copy the upgrade image:Remove the TF card from the N2 host device, and copy the image file “ltmotor-emmc-20250912-1440x720-n5-rtl8733bs-release-638530c40cb850e1c077d2f049fd1ebc.img” to the root directory of the Micro SD card.
  2. Insert the Micro SD card and start the upgrade (while the device is powered on):With the host powered on, insert the Micro SD card. A prompt labeled “Update Program”will appear on the display. Select “Update”, and the host will automatically enter the upgrade interface.Please wait patiently for the upgrade progress bar to complete. Do not power off the device during this process.Once the upgrade is finished, the host will shut down and restart automatically.
  3. Complete the upgrade and reset the hardware:After the host has successfully booted up, fully disconnect the power supplyto allow the hardware to reset. Then reconnect the power. The upgrade process is now complete.
Important Notes:
  • The new Micro SD card must be first inserted into the N2 host for formatting. Only after the host has successfully recognized the card should you remove it for the upgrade. You can ignore any other content on the card.
  • Never power off the device during the upgrade process, as doing so may result in device damage or a failed upgrade.
FAQ
Why can’t my N2 connect to Wi-Fi or access the internet?
If your N2 is unable to connect to Wi-Fi or there’s no internet access, please check your display settings​ and make sure the ​video download option is enabled.
This setting is often required to allow the device to access network resources or download content — without it, the N2 may not establish a proper internet connection.
No video after connecting the camera. What should I do?
Please check:
  • The camera is connected correctly to the N2
  • The camera cable is not damaged (e.g. bent or broken)
If it’s still not working, contact INNOVV Support:
📧 ​cs@innovv.com​ or ​info@innovv.com
The system doesn’t power on.
Confirm the ACC (yellow) and power cables are properly connected and your motorcycle battery is working correctly.
Need help?
This site is protected by hCaptcha and the hCaptcha Privacy Policy and Terms of Service apply.
