INNOVV K5 Dashcam
Find all the information you need about K5 Dashcam in here. This includes APP, manuals, firmware, FAQs, and video tutorials.
K5 Dashcam Firmware
How To Update Firmware:
1.Click the above link to download the latest firmware named K5.bin to your computer.
2.Copy the K5.bin file to an SD card. The file name must be the original name and other names could not work, such asK5(1).bin or K5(2).bin.
3. Insert the Micro SD card into your INNOVV DVR.
4. Power on your INNOVV motorcycle camera system and the firmware will be automatically updated with the green lightflashing erratically.
Once update is successful the blue light will be flashing on a regular basis appx once a second. If for any reason the update was not successful, please repeat the update.
Play Store
Download INNOVV App from Play Store
Apple Store
Download INNOVV App from App Store
Manual
K5 Firmware Version:
V1.1.12 Update 20210827
(With Default 5.8 GHz Wi-Fi)
(With Default 2.4 GHz Wi-Fi)
Changelog:
FAQ
You could kindly find the user manual for your INNOVV K5 from our Firmware & App and easily download one by clicking the icon.
You could kindly find the latest App for your INNOVV dash cam from our Firmware & App and easily download one by scanning the QR code.
1. Find the latest firmware for your INNOVV dash cam from our Firmware & Apppage. 2. Copy the bin file to an SD card in FAT32 format 3. The file name must use the original name and there can be no other names 4. The firmware is automatically updated when the SD card is plugged into the DVR and powered on
1. Please kindly check whether you are entering the Setting Interface or Camera Files Interface with INNOVV App on your phone when the INNOVV K5 dash cam system has been connected with your phone via Wi-Fi network.If yes, please kindly exit these two interfaces to further check the K5’s working status. 2. INNOVV K5 innovates with the Sony 8-megapixel sensor on its front camera, producing high-quality 4K Ultra HD video. It is significantly larger than 1080p and as a result requires a lot more storage space.Please make sure that you use a U3 (UHS Speed Class 3), V30, V60, or V90 (Video Speed Class 30, 60, 90) rated TF card.
Please kindly make sure that you have enabled the 5 Ghz Wi-Fi via Settings→Wi-Fi→Wi-Fi Band first. Then please make sure that the distance between your phone and the K5 is not that far away and there is no barriers between them. You could kindly check those smartphones which could support 5.8 Ghz Wi-Fi and play 4K videos smoothly from .
1. The INNOVV K5 is compatible with dual-band Wi-Fi, and the 5.0 Ghz Wi-Fi band is enabled by default. If you fail to search the K5’s Wi-Fi, please kindly check whether your phone could support the 5.0 Ghz Wi-Fi or not first. 2. Please kindly check that the blue Wi-Fi Indicators on DVR is flashing slowly or Remote Control. If yes, the Wi-Fi is connecting, please kindly wait for seconds to make Wi-Fi connected. 3. If your phone could support the 5.0 Ghz Wi-Fi and the blue Wi-Fi Indicators on DVR is flashing slowly, please kindly check the settings for the Wi-Fi active duration via Settings/ Wi-Fi and make sure you have chosen the “Do not close Wi-Fi” option.
New Product Notification
When you subscribe, you'll be the first to get 15% off coupons and exclusive early bird discounts!
Shopping Cart
