ThirdEYE BSD System
Find all the information you need about ThirdEYE BSD System in here. This includes manuals, FAQs, and video tutorials.
Manual
FAQ
1. Please check if the fuse is burned. 2. Please check that the wires are connected correctly and firmly. Make sure the input voltage is between 9V and 16V with 0.5A. The red wires must connect to the ACC, while the black wire connects to the negative pole of the battery.
Watch Version: Please confirm that the watch alert display’s circular connector is securely connected to the radar detector’s circular connector.
Mirror Version: Please check that the connection between the control box and the radar detector is stable.
Watch Version: Check that the radar cable connector is securely connected. Please confirm that the watch alert display’s circular connector is securely connected to the radar detector’s circular connector.
Mirror Version: Please check that the connection between the control box and the radar detector is stable. Please also check that the connecting cable is in good condition.
Watch Version: Please confirm the buzzer is not blocked on the back side of the display.
Mirror Version: Please confirm that the buzzer is not blocked on the control box.
New Product Notification
When you subscribe, you'll be the first to get 15% off coupons and exclusive early bird discounts!
Shopping Cart
